Thank You.
These pics will clarify a lot for me. There is a lot of them but this will really help me altogether.
Pic 20: These are all lightweight ballasts?
Pic 21: What do these two go as? Especially that 3 pinned one. Ive seen some that short but can have 10 pins.
Pic 22: Lightweight Ballasts? The one on the left is 4 pin (I think that came from a ceiling fan)
Pic 23: What do I do with these? Looks like a headphone jack. That metal was pulled from that piece. What does that metal go as.
Pic 24 & 25: What the heck is this? Those two discs inside were ceramic, I believe.
Pic 26: Black box is a fuse I think but no glass-does this go with the glass fuses? The second item has ferrite or similar on the outside- what should this go as? Orange item- What is it?
Pic 27: What do you do in these situations with the connections that are soldered on the board.
Pic 28 & 29: Visegrips work well on removing these. What would this go as-can this go with the various others pins that you pull out of the board ? I used to just put it with brass scrap.
Pic 30: What to do with these?
Pic 31: I read a post about these jumpers. Cut them all off and pile them seperate? I can't really notice a pink hue unless I had an example.
Pic 33: Three piles- anything special about any of these or just brass pile. Top left is from AC plugins to wall. Right is from analog video ports. Bottom left is from those little metal boxes that have a separate board in them from TVs-Just brass?
Pic 34: Similar question with Pic 37...
Pic 35: Sorted well? - all CBM#3? What is the circled item. I have seen these were it looks like a drop of epoxy with wither one or two colored circles.
Pic 37: Transistors right? Mostly copper. This is what I was talking about in my last post-the ones that are circled. The circled red have many pins. The circled blue has 4 pins. Can these just be all mixed together? The circled red ones are what I was talking about how I read that these can be classified as IC (I was really unsure about what I read).
Thank you so much.
Well you have learned, young padawan...
