It is currently Tue Jun 04, 2024 6:48 am
 Post subject: Quanity/ payout rate
PostPosted: Thu Jan 27, 2022 10:30 pm
Was wondering if the payout rate that is posted increases with quantity of products. Thanks
 Post subject: Re: Quanity/ payout rate
PostPosted: Thu Jan 27, 2022 10:57 pm
The payout is price per pound.
If you send in a pound of low grade boards at the current rate for instance, you'll get 50 cents.
If you send in a couple gaylords with 2000lbs of low grade boards, you'll get 50 cents for each pound, which is $1000.
PostPosted: Thu Jan 27, 2022 11:27 pm
If your question is do you get a higher rate for tonnage vs poundage, no.
There are situations outside of standard norms that BoardSort, like any larger scrap yard, would likely negotiate.
500 pounds of gold finger cards is just that. However, 500 pounds of Emu Xfi Gold on PCI… you’ll get ears on that.
100lbs of 8086 gold cap gold legs is just that.
100 lbs of binned for melt 40c37 proms with no glass… …!
Like any other yard. Bring in 50 tons of aluminium engines and take the irony aluminium rate.
50 tonnes of NorthStar V8s will get a seat at the table, of sorts, for discussion.
Solid gold pin wire boards do exist. Etc.
The emphasis here is on sort; not quantity.
PostPosted: Sun Jan 30, 2022 12:00 am
Thanks guys,
