It is currently Sun Apr 28, 2024 1:22 pm
 Post subject: Breaking boards
PostPosted: Mon Apr 11, 2022 5:50 pm
I have some rather long boards (15 inches) and I was curious if there would be a penalty to break the boards to get them to fit in a smaller box.
 Post subject: Re: Breaking boards
PostPosted: Tue Apr 12, 2022 12:01 am
It depends on the board in question and whether boardsort is able to readily identify that two pieces of board are actually one board.
For instance:
if you break a stick of desktop RAM in half without losing any chips you're probably not facing a downgrade, or
if you break a motherboard in half and the two halves aren't keep together, you're definitely facing a downgrade, dependent on exactly what components ended up on each half but if you keep the pieces together so boardsort can see both halves are there then.
PostPosted: Thu Apr 14, 2022 7:31 pm
Try to rubber band the pieces together, seems like a good idea to me.
