As long as there’s reasonable IC chips left it stays midgrade. However as I’ve said before with midgrade and low grade stuff I just strip them bare. I’m not close enough to send these classes to boardsort and I get 1c-6c per lb locally for the boards when they’re totally bare. The more I take off the higher I get. They buy them as “fill” and I know this stuff get sold to the local quarries but I’ve no idea what they do with them after that.
Besides when you start pulling from mid/low to the point where you’re removing that much may as well keep going. Chris has a fairly high rate for clean ICs so no reason to not pick them off too. Boardsort doesn’t buy totally bare boards though so make sure you’r local yard will buy them before you get to that point.
Attachments: |
_________________ 42 6F 61 72 64 73 6F 72 74 2E 63 6F 6D
