It is currently Tue Apr 16, 2024 7:21 am
 Post subject: Clean cell phone board
PostPosted: Sun May 20, 2018 9:49 pm
Would these be considered clean? Or do the caps need to be removed, white sticker over keypad area, etc need to be removed as well?
PostPosted: Tue May 22, 2018 2:55 pm
The heat shields need to be removed. Most can have the tops popped off with a small screw driver. Some soldered ones take more work. Large ones still must be removed . I use robogrip pliers. The design allows that with care you can crush the sides of the shields and gently twist it off without damaging (much) of the underlying materials.
If you absolutely can not get the soldered shields off the board can be sold under the telco rate (soldered shields only) but you should package it separately in your shipment box(es).
On the lower board remove the [s]lens array[/s] speaker. From this side it looks telco so post a photo of the other side so we can figure out the correct class.
Generally it’s best to leave those white key sheets on. Boardsort doesn’t care.
Removed you can toss them in your mixed wire so it’s easiest to just leave it on the board until Boardsort decides otherwise.
PostPosted: Tue May 22, 2018 3:24 pm
Bah... three hours too late. Shipped them off as is.
I did remove the speaker/mic magnet.
Thanks though.
PostPosted: Tue May 22, 2018 5:29 pm
So sorry! The post got lost in the spam and I’ve been a bit slow this last few weeks.
You’ll still clear telco at the very minimal.
PostPosted: Wed May 23, 2018 12:44 pm
yeah what's up with all the spam lately? maybe you/chris have a way to add a captcha code or something to be able to post?
PostPosted: Wed May 23, 2018 7:27 pm
A known entity. Basically a troll who is sad Boardsort took away his sandbox privileges.
He comes and goes. I delete his spam. He pops up a few days later. I delete his spam. He shows....
You get the idea.
