It is currently Tue Apr 23, 2024 9:44 pm
PostPosted: Fri Aug 17, 2018 6:01 pm
Assuming these are all telco
PostPosted: Fri Aug 17, 2018 10:27 pm
Yes
PostPosted: Sun Aug 19, 2018 1:05 am
Just chiming in here for a bit of knowledge. Can the goldfingers be trimmed and still make telco?
PostPosted: Sun Aug 19, 2018 1:17 am
Left most; maybe centre and right yes
AS LONG AS they are equally populated. Removing ICs drops values fast
PostPosted: Mon Aug 20, 2018 1:20 am
Gotcha thanks. Wanted to pass that on to JB also since he didn't ask. Lol
PostPosted: Mon Aug 20, 2018 10:58 am
Thanks for asking about that. Meant to bring that up myself and spaced it. Appreciate all the info.
PostPosted: Sat Sep 22, 2018 3:40 am
I'm not no expert or anything but wouldn't the one on the far right go as gold finger ram possibly. I thought I sent something real similar and got paid ram price for it?
PostPosted: Sun Sep 23, 2018 2:55 pm
While it’s technically and technologically memory, it’s very different from ram.
Ram cards are meant for low resistance high frequency charges with minimal leakage. Even low end and older ram modules with nickel and tin are full of those relatively pricy materials.
These are standard bus cards meant for sustained huge voltage and a constant charge. Thus there is far more low value bulk in the weight.
With a lower ic population this would fall into peripheral class. (And you’d be wise to thus trim the tiny finger)
Boards like this are not suppose to go as ram. If someone took it in as such it was a mistake.
On the other hand with slightly lower population AND the finger intact I COULD see someone theoretically giving you a trimmed ram rate for it. Which is between telco and peripheral.
