It is currently Tue Apr 16, 2024 4:51 pm
 Post subject: Vintage boards
PostPosted: Sat Aug 18, 2018 6:58 pm
I have a bunch of damaged boards from a school surplus lot I bought. Some of them might not be damaged but it would be too complicated to test each one so I might send in my first order ever. I've never had enough boards previously to make it profitable enough to send in.
I also have a bunch of old memory that isn't really as sought after as the better stuff out today so I'll probably include that as well.
My question is..are these motherboards all the same type or are there different categories for such?
I will include a couple things I need help IDing.
Do I leave everything intact or remove anything for added value?
I've done some research its just hard to completely grasp everything at once.
 Post subject: Re: Vintage boards
PostPosted: Sat Aug 18, 2018 7:00 pm
Btw I have more than that i just didn't want to over do it with photos
PostPosted: Sat Aug 18, 2018 8:55 pm
Large socket motherboard. Remove the slot CPU, with the fan. If you remove the fan from it you will get slot processor rate for it
Standing: small socket
Laying: left—small socket right—large socket
Bottom: up to Chris. Probably midgrade, possibly peripheral
PostPosted: Sat Aug 18, 2018 9:00 pm
also remove the RAM and batteries from motherboards!
