Sorry for the long list, guess this is what happens when I have too much time off work.
Attachments: |
File comment: 26, 27 backsides
File comment: So head phones jacks (28) what do they go as? Also little speakers off phone/digital recorders (29)? Also fuses (30), batteries off boards (31)? And If boardsort doesn't take them, what do you guys do with them. Will 32 be classified as cell battery? And 33 is a pieces out of a trigger on a drill it's copper but some kind of silver color plating (I have a couple of pounds of) is that consider silver plated brass and if not what is?
File comment: Backs
File comment: 23 came out of a lap hard drive so...? And 24 is the controller out of an apple earbud headset (have no clue on how to grade that)
File comment: Backsides, 21 has those little switch/button looking things I can't tell if it's gold or brass though
File comment: All the pin connectors are silver plated looking on these boards, I was thinking peripheral maybe some boarding telecom but maybe not really, I guess that's why I'm posting
File comment: Backsides. On 11 you can see the gold plating which is under both of the connectors on the other side, 13 is a printer board has all those gold pins so is it peripheral or does it rate higher?
File comment: 11 I normally would have just thrown low grade but then noticed heavier looking gold plating on it some you can't see under the connectors that are silver plated brass. 11 - 13 peripheral? And 14 and 15 are from calculators rather blank with gold plating don't know if they'd go peripheral or mid grade?
File comment: 8, 9, 10 backsides
File comment: 8 is out of a printer, 9 is a floppy drive board with gold pins and 10 was out of an old DVD rom and pins are gold on this one
File comment: 6,7 backsides
File comment: 6 is a motherboard don't know which and 7 I think came out of a scanner
File comment: Backside is blank green, peripheral?
File comment: And backside
File comment: I removed some of the components on 1 and 2, mostly it was some heavier stuff like transformers and large wet capacitors, but I was thinking still all peripheral?
