It is currently Sat Jul 11, 2020 5:05 am
 Post subject: 8086 ram
PostPosted: Sun Sep 06, 2015 7:32 pm
I recently stripped an 8086 computer took me awile to realize I wasnt going to find a cpu chip or harddrive. I thought they were putting haddrives in them by the 8086 days. now I found only a single ram chip and it does not have gold tips I did pull all the icu chips and need to see if all I pulled can be sent in for sale when I make aq shipment. Pictures here
 Post subject: Re: 8086 ram
PostPosted: Sun Sep 06, 2015 8:17 pm
The ram is silver/tin ram
You MAY find up to 6 of the DIP (rectangle) chips have gold legs. They'd be 386 class if they don't have a gold cap. or 8086 class if they do. cap may be on the top or bottom of the chip depending on manufacture and year.
Also; in a test 2 try to GENTLY remove the labels. A tiny 0 or 1 standard (flat) screwdriver to the corner of the label should lift it up and they peel off real easy. You may have a gold cap under them.
Rest of those are all going to be IC chips
PostPosted: Sun Sep 06, 2015 8:59 pm
Thank you I havent a decent shipment yet but will plan on i9ncluding them when I do.
PostPosted: Mon Sep 07, 2015 12:42 pm
Of course I'm assuming the two big cps in a test and 3 weren't part of the question.
PostPosted: Mon Sep 07, 2015 10:16 pm
nope they and the cpu were out of a pentium theyer 72 pin ram all 4 megs of it .
