It is currently Wed Apr 24, 2024 5:17 am
 Post subject: Motherboard/CPUs help
PostPosted: Thu Jan 10, 2019 8:33 pm
I'm sure the answer is already out there 100x over, but what do motherboards with fixed CPUs class as?
PostPosted: Thu Jan 10, 2019 8:51 pm
It depends on the size of the CPU, the class of motherboard, I/o etc.
This one will probably fall into large socket along with most laptop motherboards.
Looks like an All-in-one which split the large/small socket category almost 50/50.
PostPosted: Thu Jan 10, 2019 10:02 pm
So pretty much a gamble; place on "red or black" and let it ride? would I lose or gain anything if I fired up the workstation and melted that puppy off?
PostPosted: Thu Jan 10, 2019 11:00 pm
I'm quite sure this one is going to fall into the large socket category since it's a condensed (eg laptop) board with full options and a soldered Xeon CPU. Where I'd put it myself.
Removing the cpu would give you a peripheral board (at best) and a pinless CPU.
PostPosted: Fri Jan 11, 2019 12:50 am
Gotcha! Thanks for all your past and future knowledge!
PostPosted: Fri Jan 11, 2019 4:18 pm
I’m sorry if I confused you. I try to put both a specific quote and a general notation in posts where a board (type) may get different scrap classes on different boards.
All-in-one boards are such a class where most will be either small or large socket depending on both the size of the board AND the included components and options.
