It is currently Fri Mar 29, 2024 1:28 am
 Post subject: FROM HP SERVER CABINET
PostPosted: Wed Jan 16, 2019 1:54 am
Is it better to trim the fingers off oF B?
The A part is blank on bottom
PostPosted: Wed Jan 16, 2019 3:00 pm
The led board is peripheral. Lots of gold pins to make up for, well, nothing else.
If you can’t tell I really strongly dislike hp servers/industrial computers. Not that they’re bad (they’re not) but that they’re over engineered.
This fan controller is a prime example. Most companies would put this inside a smart power supply. When things die instead of replacing a $70-$90 power supply a technician needs to spend hours testing dozens of $60 boards.
Rant over
This is peripheral as is. My general suggest here is try to cleanly trim the huge fingers off. They’re worth more as fingers than on a peripheral board, which becomes midgrade
PostPosted: Wed Jan 16, 2019 5:08 pm
Thank You
