Should be the last set for awhile.
This board, I was really just curious about the resistor (I think that's what it is). It seems to be just a piece of metal as opposed to the stripe-color coded or rectangular ones you normally see. Is there a particular name for this type of resistor?
File comment: Resistor
File comment: Full board
Between the extra weight of the wire clamps and the IC population I wasn't sure if these would any better than midgrade. The square ones are the same board front and back, the rectangular one (with rect. cutout) has no population on the back.
Front and back of same board, I have maybe 60-75 of these boards and thought midgrade? If they can go into peripheral as is I won't mess with them but, if midgrade, would removing the heatsink/transformers push them up?
File comment: Upgradeable?
I know I've seen the question asked before but not sure what the answer was. Motherboards without a removable CPU would normally (or at least in the case of this board) be classified how?
File comment: MoBo No Removable CPU
Thanks again Lost for the help over the past week. I'm sure I'll have more eventually but this will help clear out most of what I have.
