It is currently Wed Apr 24, 2024 5:09 pm
 Post subject: ID please
PostPosted: Wed Sep 16, 2020 12:15 pm
Please grade this for me. Back and front of same board. Is that a battery? It doesn't want to come out.
Thanks so much!
Lynne
 Post subject: Re: ID please
PostPosted: Fri Sep 18, 2020 2:27 pm
Yes. A battery. Soldered ti it’s contacts that you removed and to the back side. Use a size 1 or size 0 standard (flat) screwdriver or a paint scraper to pop it out.
Their a pain.
Board would be low telco without the battery.
If you can’t get the battery loose find a small box. But the board inside it. Write battery on board on the box. Put the little box in the big box.
When you email your order number and tracking number for your shipment, note that a board has a battery.
This is a rare case where you can get away with not removing it as these are very difficult.
