escrapchap wrote:
1. Are there any other items I should remove for maximizing seller value or minimizing work on the buyer?
Always remove heatsinks larger than the chip it cools, or larger than a single chip, ie the slot processor
Also remove cast iron brackets from peripheral boards from old rack equipment. Big, heavy black pieces, weigh more than the board. Finally, all fans and all batteries. Fans have too much variance to accommodate for within pricing and batteries go boom.
Quote:
2. Since I am green as most of these boards...what minimal must have tools would you suggest I have in my e-scrapping arsenal to be more efficient.
toolsQuote:
3. If there are gold fingers on a board with a metal bracket, will these two combined markers ALWAYS mean the board will be identified/valued as a "gold finger card"
Any quarter to half size board (peripheral add on boards) with gold fingers and a bracket is a good guide. They will almost always fall into gold finger card or better.
Quote:
4. Photo 0035 shows a back side of a card that appears to have gold circuit wire tracing the surface or just below the surface. Am I correct? If so, how does this change board value/grading?
Alone, it doesn't. Gold value is infinitesimally low in that. Not even grains.
Quote:
5. Can you tell if the piece in 1782 may have came off the board in 1766? If so, do I need to somehow include or submit separate?
That's a cpu. The have a value separate from the board. In your case a Pentium pro.
Quote:
6. In photo files #0031, 0028, 0027, 0017 it appears that their are several geometric shaped portions of the board (primarily circles near the edges and squares on the corners) that are "gold" but has a bit of an unusual shade for being gold. ???
That's an industry standard marking for pre production signifying gold flashing circle for gold through holes, square for a gold layer. Again very low amount of gold quantity and not enough for a jump in value in most cases.
Quote:
7. I notice a lot of comments in this forum about removing connectors. Is the reference to what I see in 1876, 1874, 1753, 0090?
Removing connectors almost always is in reference to cutting the ends off wires.
Quote:
Thank you so very much!
Welcome
