It is currently Fri Apr 19, 2024 9:14 pm
 Post subject: ID Help
PostPosted: Tue May 29, 2018 4:34 pm
To whom it may concern. Need help identifying the following items. Your help is greatly appreciated. Thank you!
 Post subject: Re: ID Help
PostPosted: Wed May 30, 2018 2:51 am
1. IC chip
2. It is a gold capped chip, but I am not sure which grade it would go into.
3. Black fiber
4. AMD ceramic (no aluminum top)
5. AMD aluminum top
6. Green fiber no metal
7. No pin. The CPU may be on Boardsort's CPU buyback list, so make sure to check its model number and look for it on the list.
8. Green fiber no metal
9. Green fiber metal top
10. Green fiber metal top
PostPosted: Wed May 30, 2018 6:00 pm
20180529_162007 -1)Looks like nickel or tin legs so IC
20180529_162007-2)If no gold cap on the other side 386/486 If a gold cap on the top also, 8086
20180529_162007-3)Almost sure that's a fibre chip, so Black Fibre
20180529_162007-4)Not sure what this is. Need the other side but somewhere between pentium gold cap and AMD metal top s\ceramic
20180529_161937-1)see 20180529_162007-4
20180529_161937-2)Green/brown Fibre (with or without metal depending on top)
20180529_161937-3)-->
20180529_161719-1)-->
20180529_161719-2)-->
20180529_161719-3)-->
If it has pins, and no metal cap, green/brown fibre no metal
if it has pins, and, and a metal cap, green/brown fibre with metal
if it has no pins, winless
