It is currently Fri Apr 26, 2024 5:52 am
 Post subject: A $2 metal multisocket?
PostPosted: Wed Aug 01, 2018 8:06 am
so? is this really only $2/lb.?
PostPosted: Wed Aug 01, 2018 2:15 pm
Yes. But looking at the reasoning it makes sense
When you look at the size of that unit, server boards in general, what is really added over a standard single socket boards?
The two things that push a motherboard over peripheral, beyond the obvious of a socket or soldered cpu, are internal connectors and the I/O chipset.
This has no internal connectors so; We’ll let the extra, less valuable, ram ports make up for the missing BUS ports.
Looking for the I/O system, this may have 4 sockets but only one I/O set. It’s the rectangle set-off in the middle.
If you were to cut this board into clean even quarters you’d have four peripheral boards as none would have all the requirements for motherboard.
A/V rack control computers, terminal hosts, and cube servers, and some blade base boards, are about the only places modern-ish motherboards make the telco grade as they duplicate everything, on much more expensive heavy sandwich boards with a thick layer of copper or silver running the centre layer of the entire board.
Hope that clarifies the reasoning
PostPosted: Wed Aug 01, 2018 7:09 pm
Great write-up Lost. One other question, but I doubt it will change anything. What if the the metal brackets were removed. I know there is the same amount of "Good Stuff", but does less "Bad Stuff" figure in at all?
PostPosted: Wed Aug 01, 2018 11:15 pm
There’s not enough IC nor precious metals in general for this to move any higher.
PostPosted: Thu Aug 02, 2018 4:01 pm
Thanks for the info. Starting a new post now. I've got a 55 gallon drum of e-soup to sort.
