Well if you know they work you could sell them for used items. As far as scrap goes the first mono is a LG socket, $2.80/lb, at about 1.5 lbs I'd say, then gold finger cards are maybe $3.75, and Id say 1lb tops by the two you have. Then the metal socket board is in it's own category now at $.95/lb, but there a little heavier, so that board may be just under 2 lbs. Slot cpus are 10.50/lb, just over an ounce a chip I believe, so you got what, 10 in scrap tops. If you'll be getting more save it up. Or try selling it online if they work, and you know they do. Don't waste your postage sending just that into boardsort.
