It is currently Fri Apr 26, 2024 3:38 pm
 Post subject: disk drives,tape drives
PostPosted: Sun Feb 09, 2014 8:48 pm
hi i'm new to e-scrap i was wondering boards from tape drives and disk drives what would they be classified as and if i had any questions about boards could i post the pictures on here to get a classification of it tank you for all the help
PostPosted: Sun Feb 09, 2014 9:22 pm
The boards from a floppy disk drive will be considered Peripheral Grade as long as they still have the connector pins on the board.
The board from a PC CD-ROM/DVD unit has its own grade, which at the time of this post is $2.65 per pound. These boards must be cleaned of all ribbon wire as well as any smaller brown sided accessory boards that may be hooked to those wires.
You are welcome to post pictures of boards you have a question about, in fact we encourage it. There is a forum devoted to that very thing:
"What is It? Identification Forum"
http://boardsort.com/escrapforum/viewforum.php?f=4
PostPosted: Fri Aug 28, 2015 6:38 pm
I was also curious about tape drives. I just purchased a ton of them and would bet they fall into cd/DVD category. But figured I would post and find out. They are pretty populated so it also wouldn't surprise me to be able to get telco or hard drive price out of it. But I'm just a new guy. I will see what boardsort has to say. Here is an example of one....
PostPosted: Sat Aug 29, 2015 12:17 am
That's peripheral
PostPosted: Sat Aug 29, 2015 12:23 am
Really? It seems better populated than some of the cd/DVD boards I've pulled. And gold pins. What makes you say peripheral? Not disagreeing just trying to learn so I can figure it out on my own.
PostPosted: Sat Aug 29, 2015 12:36 am
I think you would be able to get cd/dvd board classification for those... Hopefully Chris will be able to give you a definitive answer.
PostPosted: Sat Aug 29, 2015 11:14 am
I think (I'm not them) it's the number of pins as the ports are shorter. ?
I only say peripheral because a bunch of jazz and hp boards i sent in for review . Not quoted . Were taken as peripheral.
Maybe Chris could clarify this.
PostPosted: Sat Aug 29, 2015 12:20 pm
I sent Chris an email. I will post the answer when I hear back. Fingers crossed.
PostPosted: Mon Aug 31, 2015 12:23 pm
You were right. Chris says peripheral.
PostPosted: Mon Aug 31, 2015 3:09 pm
ah, bummer.... i figured a well populated board like with a couple chips and all would make the cut... oh well. :/
