Boardsort.com
It is currently Sun Feb 23, 2020 8:03 pm
 Post subject: 386DX
PostPosted: Mon Jul 20, 2015 10:20 am
I got a 386DX the other day. Looks like 2 ceramic processors, maybe a math co-pric and a main proc? Eaither way, they dont have the ZIF release handle, how do I get them off the board without damage?
 Post subject: Re: 386DX
PostPosted: Mon Jul 20, 2015 12:14 pm
Use a pair of adjustable needle nose pliers.
If you don't havr that a spudger works.
I use the plastic over aggressive one from ifixit.
https://www.ifixit.com/Store/Parts/Heav ... F145-013-1
Or make your own. :)
Lifting from the corners works the best. Just slide the spudger under the corner and rock it gently. When it lifts a bit move on to the next corner.
Once all four are released it should come easily if you grab two sides and pull up.
PostPosted: Tue Jul 21, 2015 1:05 am
I have seen some that are directly soldered into the board... if you have one of those, a heat gun is your best bet. DO NOT use a torch! Burning a printed circuit board is HIGHLY toxic.
The vast majority of 386's are in a socket of some sort though. In which case a small awl can usually be used to pry up a side at a time like Lados said.
M
