It is currently Sat Feb 16, 2019 10:34 pm
 Post subject: Power supply boards
PostPosted: Sun Nov 27, 2016 10:52 pm
What class do these fall under?
 Post subject: Re: Power supply boards
PostPosted: Mon Nov 28, 2016 1:38 am
depends... I have seen them range... usually they are green on one side and brown on the other, which i think is mid-grade (i could be wrong, it has been a while since i torn apart a power supply)?
i think low grade is brown on both sides.
PostPosted: Mon Nov 28, 2016 2:57 am
Almost almost always low or Midgrade. And more often low.
Specific server and minicomputer power boards can go higher with extensive cleaning and removing of specific items; but you'd know those instantly by gold and silver fingers on multiple sides; and giant gold wedge pin sockets. The special boards also weigh almost 20 lbs out of the case and again require extensive cleaning of excess weight before you finish with about a 5 lb peripheral board and 15 lbs of aluminium and CBM.
PostPosted: Wed Feb 15, 2017 10:43 am
Are power supplies worth breaking down?
PostPosted: Wed Feb 15, 2017 1:22 pm
Only if you get a better rate for the board than the whole power supply;
Or if there large gold fingers or pin connectors, gold, not nickel or tin
