It is currently Tue Apr 23, 2024 3:50 am
PostPosted: Tue Feb 27, 2018 12:37 pm
Do they still buy the item even though it only has a light weight? For example, only 1 or 2 pounds of IC Chips. Thanks!
PostPosted: Thu Mar 01, 2018 7:19 am
I can give an opinion based on what I have read here since I have not delivered my scrap as yet but soon. I think if you follow the procedures when mailing in I don't think they would have any problem with that weight of ics but it may not be worth it to you. You may want to wait to collect a bigger amount and send in other items with them since you have ics I assume you may have boards also. Since you have taken the time to join it shows you may be in it for a longer run of scrapping.
PostPosted: Thu Mar 01, 2018 3:00 pm
Ideally you would want to send at least a few pounds total; enough to cover shipping fees.
Chris has told me to make sure the weights are enough to tip the scale. Meaning 2-4 ounces minimum.
This can make sense in a multi item order if your sending, inx, 8 ounces of gold cap CPUs or 6 ounces of ram with 5 lbs of motherboards.
To send ounces of a class I highly suggest you put a 0 in the pound box for the class on the quote form. Some modern browsers don’t play nice with the quote form when pounds is blank.
PostPosted: Fri Oct 19, 2018 6:12 pm
do I remove transformers and the copper from boards?
PostPosted: Sat Oct 20, 2018 1:22 am
Generally not. But you can always post pictures if you want to be sure
