It is currently Fri Apr 26, 2024 6:26 am
PostPosted: Sun May 27, 2018 11:47 am
Greetings all . . . Happy Memorial Day weekend!
I'm trying to contact a member of this forum who is also a member of the GRF board (which has been down).
I just noticed that when I want to view a Boardsort forum member's profile, the search function tells me I am not authorized to view the Boardsort member list or profiles.
How can you be authorized or is this search feature for mods and admins only?
Peace all,
James
PostPosted: Sun May 27, 2018 10:27 pm
The profiles have both public and private information. From what I can tell on the user end (not at Boardsort infront of the server or a terminal) is the filter is inactive to keep the two separated in viewing.
Which would explain the profiles being kept private.
Unfortunately there’s also a bit more than clicking a toggle to activate the filters.
Unfortunately the GRF is a bit zealous in its privacy; it’s not indexed at all, anywhere. So I cannot help with that.
If it’s a user you know is on both and have interacted with befor just post below this and give a shout out, hey, xyz, contact me
Follow on here, I believe the profiles were killed from the public space when the message system was turned off.
You can see the damage our spam rat does with just topic posting, so you can imagine what they did with more access before.
PostPosted: Mon May 28, 2018 8:00 pm
Thanks, Los.
Good luck with exterminating the "spam rat".
James
