It is currently Tue Apr 16, 2024 2:58 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
 Post subject: Sewing machines
PostPosted: Wed Mar 01, 2017 1:31 am
File comment: This was on each side of the motor
File comment: These two boards was attached, and the larger board has a good deal of weight
 Post subject: Re: Sewing machines
PostPosted: Wed Mar 01, 2017 1:53 am
Here's a side view of the two larger boards
PostPosted: Wed Mar 01, 2017 10:04 am
The power plug is nickel plate and goes in dirty brass.
For boardsort the larger power board is midgrade. Remove the Al it's worth more on its own.
The smaller board is peripheral AFTER you remove the aluminium from it.
Those tiny boards are probably low grade
Nice pickup.
PostPosted: Wed Mar 01, 2017 10:07 am
Correction that controller board very well could go as telco!
Remove the st unit. It's a battery
Should be socketed
PostPosted: Wed Mar 01, 2017 9:31 pm
Thank lostinlodos, got several of those boards, and once they go threw the older machines I'll get those as well.
PostPosted: Thu Mar 02, 2017 5:34 pm
The older ones are where you're definitely going to need to post photos and may yet need onsite verification. Older boards from anything need extensive reviews outside of some standardised stuff. They can be orders of magnitude better than current tech; or worth almost nothing at all. So post as many pictures as you need to to be sure
PostPosted: Thu Mar 02, 2017 10:27 pm
Thank you so much!!
I am VERY APPRECIATIVE of yours and everyones time, knowledge, experience, and patience!!
PostPosted: Fri Mar 03, 2017 1:58 am
Older being early 80s and back.
Much of that stuff had human interaction at some point in assembly and humans introduce inconsistencies!
I've had power boards from 300 series iBM minis get telco rate and stuff from old projectors and a weaving machine get $20+ per board from jewellers. . Many many ounces of silver. Lbs in some rare cases. And old deck controllers (16" hard drives) go as midgrade. :'(
Anything older than the very early 80s; values are all over the place!
Hint; the only one I'll give here on this stuff in general,
Old educational stuff like spell with me. Learning mate. ...
Some old "adding machines" (aka calculator) . Silver solder thick enough to literally use pliers to rip it off.
At $7-$10 per ounce for 80/20 silver; money.
Or you get some fast lasy bum made board with so little solder it died six months later and is worth low grade today.
PostPosted: Fri Mar 03, 2017 2:40 am
WHOA!!!!
that sounds like payday!! Will definitely start watching the yards sales and curbs better. Pick up crazy s@% with cheap to free price tags.
PostPosted: Fri Mar 03, 2017 2:57 am
Lisa Yates wrote:
WHOA!!!!
My warnings remain the same as I made in other related posts; know you're gambling and never spend more than you can loose. :)
