It is currently Fri Apr 26, 2024 7:29 am
 Post subject: Any suggestions?
PostPosted: Wed Apr 04, 2018 9:34 pm
Any suggestions as to how I can get this lithium battery off? There is a small gap between the board and the bottom of the battery.
 Post subject: Re: Any suggestions?
PostPosted: Wed Apr 04, 2018 10:40 pm
These are almost always pined. My suggestion if it hasn’t been turned on in the last few months is very gently slide a standard (flat) screwdriver underneath and slowly work it loose. If it has been powered up or you don’t know you can use a box cutter to remove any external sealer and then gently rock the box loose with a plate of lock jaw, slip jaw, etc pliers.
PostPosted: Wed Apr 04, 2018 11:54 pm
Looking at the back of the board it appears to have pins sticking thru the board and soldered. My guess isthey have been out of service for well over a 6 months just from talking to the guys at the school where I bought them. I'm to scared to heat up and melt the solder so I will try prying it up with a screw driver.
Wait a minute I can use a wood cheisel and cut the board around it. It's mid or low grade anyway. :)
PostPosted: Thu Apr 05, 2018 3:23 pm
A pair of size 2 tin snips would probably be easier. Or one of those fiskars “titanium” ratcheting pruners. Best $20 pruners I ever bought. Slice right through computer boards. :)
PostPosted: Thu Apr 05, 2018 9:06 pm
Ohh another tool :)
I just got a small pair of frisker shears that I like really well so far.
PostPosted: Thu Apr 05, 2018 11:54 pm
on amazon
