It is currently Fri Apr 26, 2024 12:28 pm
 Post subject: Old PA-600 MAS H.D.P.-U
PostPosted: Tue Aug 21, 2018 8:53 am
I have a few of these old boards with nothing implying gold except for about six gold legged transistors. Would Boardsort want them, or should I frame them and hang them on the wall as vintage nerdArt. Even if Boardsort takes them, it appears to me that they would be low or midgrade, so less than 50 cents for the board.
PostPosted: Tue Aug 21, 2018 3:29 pm
This stuff varies considerably and judging from photos is difficult.
Generally speaking you’re looking at midgrade or peripheral for most boards like this.
It depends on the amount of flashing and trace, and what the trace material is.
These Olson often have copper sheets in between the polymer board layers. Though rarely solid sheets; usually strips where large amounts of through hole connections are made.
Silver trace copper boards normally get peripheral.
Unfortunately boards like this the ONLY way to class them is to hand it to someone for a quote. Eg, send them in.
PostPosted: Tue Aug 21, 2018 3:52 pm
I will have a load to deliver in person before the end of the month, so no problem bringing them in for a look and quote, and of course sell.
PostPosted: Tue Aug 21, 2018 9:49 pm
That’s actually the best wAy to do it.
PostPosted: Tue Aug 28, 2018 3:16 pm
I have a lot of these too from tearing apart vintage testing equipment. Your info helps a lot.
