The first two would need to be quoted out on reception they’re better than gold pin connector most of the time and not good enough for pin or peg board classing. 3rd photo, the green board is peripheral. The brown board is low grade UNLESS the etching is gold. Where it would definitely receive an upgrade, probably to peripheral.4th pic the GE board is peripheral and the boards with the big capacitors are low grade. Last board is low grade. My suggestion is grab a set of slip jaw pliers and rip the pin connector off for clean gold pins, or if you don’t have slip jaws grab regular pliers and snap the boar. It would fall in line with the first two photos.
_________________ -- my grades are my own and do not represent an offer from boardsort, nor are they guaranteed. Please keep that in mind.
