It is currently Fri Apr 26, 2024 3:59 pm
 Post subject: When to remove ICs?
PostPosted: Mon Apr 15, 2019 7:31 pm
Thank you to Lost for answering my board grading posts.
The next question relates to the removal of ICs. Under what circumstances should they be removed vs. not?
I have a number of CD/DVD drive controller boards. Some of them have 1 or even 2 removable chips. Is it ok to remove these?
Thank You.
 Post subject: Re: When to remove ICs?
PostPosted: Wed Apr 17, 2019 7:50 pm
That depends. For on topic I’m assuming little squares in plastic sockets. On something like a drive controller that shouldn’t be a problem; but the occasion big IC in a large square plastic socket, leave those on. That’s likely the controller that makes them Cd/DVD grade. Generally if it’s in peripheral grade (or better) a single IC isn’t going to kill the grade. I pull bios chips from boards all the time. And will typically pull the single cache chip from magneto-optical (floptical) drives. I don’t ever remove ICs from telco. It’s rude to boardsort I’d its still telco, and risky in I could pull just one more and then have peripheral.
Generally I don’t recommend removing ICs unless they are socketed in motherboards. Or on specific occasions when grading boards in photos here.
