It is currently Fri Apr 19, 2024 7:23 am
PostPosted: Tue Feb 24, 2015 11:59 am
[edit]not so obvious searches answered most questions for me[/edit]
hello. Doing my first attempt at selling to boardsort. I've been using a others in the past plus two local yards. What I've found is everyone had different "terms" or ideas for what boards are what. The local yard and the PM refiner I was using simply went by High/mid/low levels on blank, copper, silver, and gold board sorts. Using the industry standard corner hole markings for classification. Locally they go by "grade" so I'm lost on what is what by "types" ie mid high vs mid low and high grade vs mid grade and well.
Any chance you could help me reclassify these for sending to boardsort?
There's more than what's photographed too. mostly identical or nearly identical so I only did the basics. I'm sorry there's so much. Just totally lost on where your differences are. Took front and back of most of them.
Wifi units. Silver plate edges
Silver fingers and contacts. Seperate wire contacts from board fingers or all together?
Gold boards.
Silver Wireless phone boards. With Controllers.
D. Card Boards
E Telco?
Standalone Rom controllers (video games). As green fiber or something else?
Flat wire and silver laminate together or seperated
Gold contact boards. As slot processor. fiber? something else all together?
Gold caps?
Gold fingers and wire ends. Sort by type or all together?
Class?
Green Fiber?
hematite and Ferrite. do you buy? if so how much?
Controllers. Clean. Green fiber or something else
Gold plated print head base. Class?
Roms or something else or not at all?
large lots of mixed items. Some have gold ends and controllers. Slot cpus? the tube screens are palladium. Copper contact board. Gold flat wire but fully populated?
Uh. Totally at a loss on how to class these.
again sorry for super long first post. I always wind up with this stranger stuff. heavy Gold on one side and brown on the back? grr. Any help is GREATLY appreciated.
PostPosted: Tue Feb 24, 2015 2:43 pm
most of the items you have questions about they have pictures describing what each classification is.
Most of the boards you have depopulated enough to downgrade most of them. almost all those boards you posted would be preiferal grade or less. They are looking for the IC chips and BGA chips on the boards, so leave them on and you will get the full grade.
I am not a mod though, so you would have to wait for their opinion.
M
PostPosted: Wed Feb 25, 2015 9:17 pm
Thankyou.
PostPosted: Thu Feb 26, 2015 5:34 pm
I would recommend you to post less than like 7 pictures at a time. Being so many pictures it is hard to follow and answer the post for any member to give you their two senses.
Board sort only buys the Li-Ion batteries from cell phones and laptops and you have to tape over the exposed metal contacts to avoid a possible explotion.
Go ahead and read some of the other forums to get a sense of what you want to sell to boardsort and to your local scrap yard based on yor location and the cost of shipping.
Hope this helps a little bit.
PostPosted: Tue Mar 10, 2015 5:28 am
Thankyou
