It is currently Sat Apr 27, 2024 12:00 am
 Post subject: Slot processor
PostPosted: Sat Mar 22, 2014 8:02 pm
If I pull the board from the processor what CPU chip does it fall under?
 Post subject: Re: Slot processor
PostPosted: Sun Mar 23, 2014 6:44 pm
It may downgrade the board from slot processor to fingered card should the fingers remain intact. If the fingers get removed along with the actual chip, you will be looking at a mid-grade board most likely. My advice is don't remove it so you can get slot processor pricing.
PostPosted: Mon Mar 24, 2014 10:39 am
I agree, the best way to sell a Slot Processor is intact. Everything said is correct about the results. The chip itself would likely pay as a NoPin because you will probably not get the pins out intact, and it will have a metal cap.
Save the time and trouble and earn the most by leaving them as is (of course you must remove it from the plastic case and heatsink, but I assume you know that.)
PostPosted: Mon Mar 24, 2014 8:05 pm
Thanks
 Post subject: Motherboards
PostPosted: Mon Apr 14, 2014 12:28 am
If I take the gold plated pins from the motherboard will it reduce the price per pound or will it stay the same?
PostPosted: Mon Apr 14, 2014 3:24 pm
It will reduce the board considerably. How much? That depends, but it will likely be more than 1/2 only because once a board is modified, the accepted known value becomes invalid and at that point we are merely guessing on value. When it comes to buying, we like to avoid guessing so I would suggest leaving the boards unaltered.
