It is currently Tue Apr 16, 2024 2:45 pm
PostPosted: Sun Apr 20, 2014 9:07 pm
This is from an old Toshiba laptop, I think it was a card slot. Where would I sort this?
File comment: from Toshiba laptop view 03
File comment: from Toshiba laptop view 01
File comment: from Toshiba laptop view 02
PostPosted: Sun Apr 20, 2014 9:39 pm
As-is, I would put it with your cable ends. Remove the board that the cards socket into and you can put it with your peripheral boards and the metal can go to your local scrap yard. If any metal that is gold plated gets removed in the process, boardsort can evaluate it and give you a price on it.
PostPosted: Mon Apr 21, 2014 10:26 am
You can sort that into your Peripheral Grade as is, not modification needed.
Thanks for the look!
PostPosted: Fri Apr 25, 2014 11:21 pm
Thank You
