It is currently Tue Apr 16, 2024 4:12 am
PostPosted: Tue Nov 29, 2016 2:38 pm
I was wondering if I take off these gold chips or keep them on the chips say 8324 or 8332 and what grade are they if I take them off. Thank you for the help
PostPosted: Tue Nov 29, 2016 4:25 pm
that is a beautiful board... as it stands, you would make more by removing them with a heat gun. if they are soldered and you try to pull them off, they will break and not be worth anywhere near as much.
BUT....
boards like that are sought after by collectors. You can try sending an email to Cris to see what they would give you for that, or you can throw it up on ebay to see what it would fetch.
Also, a safety note... unless you are set up to remove chips (ie. - proper tools, proper fume control, protective gear, etc.) I do not recommend going that route... smoke from a pcb board can kill you in a confined space.
PostPosted: Tue Nov 29, 2016 4:34 pm
alright then I'm definitely not set up to take them apart guess I'll email Chris like you. said. and thank you for your answer.
PostPosted: Tue Nov 29, 2016 4:59 pm
Absolutely wicked board.
