It is currently Thu Apr 25, 2024 11:21 pm
PostPosted: Sat Apr 14, 2018 9:26 pm
#1
#2
#3
#4
#5
#6
PostPosted: Sat Apr 14, 2018 9:31 pm
no #7
#8
#9
#10
Should I remove the heat sink from this DDR memory?
#11
Are these ok as connector ends? All have gold
Sorry about some of the pictures.
PostPosted: Sat Apr 14, 2018 11:11 pm
1. Small socket colored motherboard. The CPU will go into green fiber metal top.
2. Metal socket colored motherboard
3. Metal socket green motherboard. The CPU will go into pinless.
4. Large socket motherboard. The CPU will go into green fiber no metal.
5. Metal socket green motherboard
6. CD/DVD drive board and two peripheral boards
7. The board on the bottom-left is a cell phone board. I am not sure which grades the video card and the large board go into, but one would have been a gold fingered card and the other at least peripheral if the chips were not depopulated from the cards.
8. Green fiber metal top (Pentium 4) CPU and midgrade board
8. RAMBUS/metal cover RAM, three gold fingered cards and CD/DVD drive board.
9. 12 of the boards are definitely low-grade and the rest are at least midgrade. I am not sure if any of them go into connector ends.
Make sure to remove all CPUs, batteries and heatsinks from boards before sending them. Some CPUs may be eligible for Boardsort's CPU buyback program; make sure to take note of the CPU's model number and check if that is on the list of eligible CPUs.
PostPosted: Sun Apr 15, 2018 7:18 pm
Thanks much. All those youtube vids showing how to remove stuff didn't help me here.
PostPosted: Tue Apr 17, 2018 8:21 am
I'm soldering components back onto the depop'd boards. Hope that restores content.
PostPosted: Tue Apr 17, 2018 5:44 pm
4) may be small socket. Given the AMD k7 era cpu in the socket. You'll need to measure it.
6) ignoring the mobo on the top
top left peripheral (floppy board)
Centre left peripheral
lower left Gold Finger Card. Need Better photo of this, some sound cards clear telco
top right peripheral
lower right looks peripheral.
7) top left gold finger card
bottom left cell phone board
right Peripheral (don't cut the fingers)
8) flip the big card over so we can see the other side of the finger. it MAY clear peripheral.
9) Corsair memory usually has screws or clips in their sinks. See if you can easily gently remove the sink from the ram for much more valuable clean Gold finger RAM
last photo
most of that is low grade. TV/monitor boards. Drive motor boards, etc. looks like someone got into an iMac. too. left side small board with giant ic is mid grade. centre top smart connect board is mid grade USB board is peripheral.
tow long boards left centre go as peripheral.
remaining green boards are mid grade, brown boards are low grade
The "flat wire" connectors, need the wires trimmed off for gold pin connector. the metal power port is almost certainly brass, not gold. the rest looks good for gold pin connector (from what I can make out).
