It is currently Fri Apr 10, 2026 5:01 pm
PostPosted: Thu Apr 09, 2026 12:55 pm
I have some bigger bits of brass that I wanted to send in to board sort with my next shipment, Does the brass I send in need to be 100% clean or can it have solder, paint and bits of copper on it? think brass fittings with a bit a copper pipe soldered to it and the likes.
Thanks !
PostPosted: Thu Apr 09, 2026 1:18 pm
I may not remember the percentages correctly but I think common practice is brass can be called clean brass as long as it's 85% brass by weight.
I always shoot for 100% personally but it's nice to know I don't have to be perfect with it.
PostPosted: Thu Apr 09, 2026 1:24 pm
yeah I did not see clean brass in the category so that's why I asked. most of what I have is 90ish % brass. so I'm likely good.
PostPosted: Fri Apr 10, 2026 12:58 pm
Paint won’t be an issue unless it’s lead
Same with solder.
Copper mixed in won’t work for clean brass recycling. You can quote it as such though. So mark/box it as mixed brass accordingly. And call to let them know.
