It is currently Wed Jun 24, 2026 7:26 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Jun 19, 2026 3:59 pm
lostinlodos wrote:
@austin86
My reply was for anyone other the. You. ;)
No seriously
Have a monitor before 1998 email me. If it powers up, I can fix it don’t need screen video, just if it turns on don’t care size will buy
how far are you from Ohio ??? would you be interested in a tube tester/rejuvenater too ? I find CRT TVs all the time and more or less stop bothering to try to sell them as I can never find anyone to take them even for free and working. why pre 1998 tho?
PostPosted: Fri Jun 19, 2026 4:38 pm
He's closer to the antipode of Ohio at the moment lol
PostPosted: Fri Jun 19, 2026 8:48 pm
lol i know i saw his post. looks like he's at taal lake in the Philippines.
PostPosted: Tue Jun 23, 2026 1:44 pm
OK had some stuff come up this weekend so I did not get it all done but I'll spot what I have so far.
That's a lot of shielding.
What a beefy neck/yoke
VGA input board, this had the shielding soldered on and I cracked part of the board off. Kinda wandering what grade it is, there is gold pins in the blue and white connector and the VGA port too.
Not a lot going on with the main board, a few IC's but it's mostly a low grade board. I"ll remove the ICs and the alu heat sinks as I have use for them.
Yoke, does not look like a lot of copper in this one but we will find out.
Neat !!!
Ok now for the wights.
the yoke as is is 1lb and 5.2oz, the copper pulled form it was a smidge over 7oz sp well worth taking the yoke apart for the copper.
I have not weighted everything so the weights will change/update soon
around 7.5oz of number 2.
around 1lb of degaussing coil wire, I have not checked if its alu or copper yet.
around 8oz of mixed wire.
around 4lb of steel.
around 1oz of ICs
boards and alu heat sinks not yet weighed, I"ll get exact wights latter today or tomorrow and post the payout/hourly rate earned from it. I'm guessing its around 10$ and hr
