It is currently Sat Aug 08, 2026 1:32 am
Post new topic Reply to topic  [ 15 posts ]  Go to page Previous  1, 2
 Post subject: Re: Copper windings
PostPosted: Thu Aug 06, 2026 12:15 am
It wasn't copper...
...sad day, but now I have a nice heavy doorstop and some aluminum wire
PostPosted: Thu Aug 06, 2026 12:46 am
Not to drag you on, but if it’s old enough have it scanned xrf: may be nickel or tin.
Both are worth more than copper.
Could be a low end white metal (which has a small bit of gold) which generally is in the high bid range per copper.
or a mid range 300 series stainless or a 1440 steel as well. Same range per in the $1.5-2.5 realm. It could be aluminium— if it is it will be an alloy for such a use and have a bit of tin in it. Or nickel.
Despite the coating You should be asking for aluminium drink can rates there not #2 or 3 clean.
If you have less than 10 lbs skip the fight. But cut about 1-2 inches and smash it flat with a hammer. Grab a high end magnet (like a hard drive mag) or your cobalt stick magnet (you *DO* have one right? They’re less than$10 for a set of 3-5 on amazon!). If there’s a movement you have a stainless or nickel containing alloy and less than $1 per pound is a slap in the face.
Just saying
PostPosted: Thu Aug 06, 2026 3:39 pm
It's not much, but I'll check. I don't think I have the fancy magnet but plenty of hard drive ones.
58 pounds on the core
PostPosted: Thu Aug 06, 2026 7:30 pm
lol, I was talking about the coated copper.
The core is usually iron or stainless steel
, sometimes aluminium.
PostPosted: Fri Aug 07, 2026 3:32 pm
I know...
Just wanted to share that chunk¯\_(ツ)_/¯
