It is currently Sun Oct 11, 2026 7:15 pm
PostPosted: Fri Oct 09, 2026 5:27 pm
I have 3 MRI units worth in total of superconducting wire from 1994-2014 era Siemens magnetom (1x symphony 2x impact) that I can't easily get rid of for it's true REE value. Does anyone have any ideas or guidance on this material?
PostPosted: Fri Oct 09, 2026 8:22 pm
Do you know what the wire is made out of?
If you can get a scan and tell me what it actually is, and a zip code, I may be able to point you to a buyer locally or one with some sort of shipping offset.
And depending on what it is if boardsort isn’t interested I’m still doing middle-man buys for some things as I go through my current stuff in life.
PostPosted: Sun Oct 11, 2026 4:04 pm
The clips are what's left after I etch the copper away and boardsort isn't interested. I'm located near 18407
PostPosted: Sun Oct 11, 2026 5:46 pm
Titanium and Niobium.
In order
Clean pure titanium is running around $1 to $3 per pound on the higher end. Most buyers at at $0.25-$0.60
Niobium is between $25 and $35 a pound.
As a mixed alloy I’d assume you’re in the $10 range or so.
Titanium is extremely valuable only when it is above 98% pure. And rather inexpensive when anything less than that.
Niobium Is a rather limited use material. You have the key use in front of you. As well used for some speciality steels and various electronic components.
Give me a bit I’ll look up anything in your area.
PostPosted: Sun Oct 11, 2026 6:06 pm
If you want to email me I can give you a list of potentials, a probable if you have enough.
