It is currently Wed Jul 29, 2026 7:53 am
PostPosted: Sat Nov 20, 2021 2:50 pm
So far no solid copper wires.
My fourth burn, shown, has again failed to find value.
3 tin plated aluminium, with tiny copper core.
One copper plated aluminium.
Meaning the cloth and copper mesh cover is the majority of value. Eg, none.
4 non-phone brands from $4.99-49.99. No solid copper.
As a side note I’m wondering how this is “better” for the environment over cables. Just as much wire is used inside the charger. In fact when you add the external cable for the magnetic charger… we’ve doubled the wire. And considerably more plastic.
On the plus side all plastic was clearly stamped with not just a 7 but the actual plastic chem code. Proper recycling at a drop off was easy. Good to see we’re making some progress on that front.
PostPosted: Sat Nov 20, 2021 2:51 pm
Just toss the cable in mixed wire.
