It is currently Wed Apr 15, 2026 1:26 am
 Post subject: Connector ends
PostPosted: Thu Mar 05, 2026 5:28 pm
Do I need to be wary of connector ends that have a gold color but are actually just brass pins? I know there are industrial cables built this way, but I don't know if there are PC cables built this way.
Thanks
 Post subject: Re: Connector ends
PostPosted: Thu Mar 05, 2026 8:38 pm
Yes. If there's no gold, it won't be a connector end.
PostPosted: Thu Mar 05, 2026 10:26 pm
In reality bare brass in electronics connectors are quite rare. Rare enough I wouldn’t worry myself over it.
PostPosted: Tue Mar 10, 2026 2:50 pm
Wile it is rare its not unheard of in audio equipment. My rule of thumb if its not audio retailed its likely gold, if its audio retailed take a closer look. I found brass being used in cheap "gold plated" RCA and TRS jacks more than once. normally you can tell by the tint, gold brass
PostPosted: Tue Mar 10, 2026 4:22 pm
I’m with you but a lot of that stuff is still technically gold plated.
I deal with pm and have the supplies so I line them up and scratch test them with 8K acid blend.
Gold is good and brass goes in 3-brass recovery.
PostPosted: Wed Mar 11, 2026 10:13 am
true but I found a lot of it is brass to, more is gold plated by far but I came past enough brass audio stuff being pass off as gold plated that I always take a closer look before chucking it in the connector end pile, better safe then sorry after all.
