It is currently Mon Oct 26, 2026 4:29 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: Fuses
PostPosted: Mon Oct 17, 2016 3:42 am
You'd need to email or call Chris directly to find out if they're interested.
And I'm not ignoring your batteries just didn't get to it yet.
PostPosted: Mon Oct 17, 2016 6:10 am
I sent the email yesterday, waiting on a reply.
Whats your opinion? Should i hold off on sending in the boards? May need to go threw them once more.
PostPosted: Mon Oct 17, 2016 1:11 pm
I have no CLUE what the value is. It's not anything I've ever had enough of to sort separately. I know both Asia and gigabyte make boards with them but I've honestly just left them on the boards and ignored them.
Best guess; 25-75c per lb. if they take them they'll probably do so at midgrade or gold pin connector rate. And more likely the midgrade rate.
PostPosted: Mon Oct 17, 2016 1:17 pm
Will i be down grading the board if i take them off?
PostPosted: Mon Oct 17, 2016 1:51 pm
No, not at all, but you're removing weight from something that is almost certainly worth more than the caps you're removing.
About the only place I could see capacitors being above the peripheral value is the ones from the Gigabyte FX boards and I7 boards in the extreme and gold series, where the entire canister is gold plated. But in these cases the board has enough gold to surpass the small socket value anyway (requires on site review). The few I've sent in of those have gone telco.
So again removing the caps even there is reducing overall value.
PostPosted: Mon Oct 17, 2016 3:05 pm
Ok thanks
PostPosted: Sun Oct 23, 2016 6:23 am
OMG OMG you are not going to believe what I found, was cleaning yesterday and stumbled across the cases for scanners, YEA ME!! The only thing is ,tye the smaller boards that go on each side of the laser assembly is now either in the peripheral or low grade box.
One even has a red soft case,sorta like what you would put on a phone. And i have about 3 or 4 pocket sleeves also. Im excited. Going to clean them up and send you some knew pictures.
PostPosted: Sun Oct 23, 2016 12:49 pm
Yippee!
