It is currently Fri Oct 30, 2026 2:37 pm
PostPosted: Wed Dec 16, 2015 3:39 pm
Hey does anyone know what to do with the old 3.5inch disk drives??? I have quite a few and I do not see a listing on boardsort buying them. I know that they are "quite old tech" but am in a pretty rural area so am seeing them on old puters.
Any ideas???
PostPosted: Wed Dec 16, 2015 4:58 pm
I break them down since it's just a dozen screws or so in all.
You get aluminum steel copper some wire and a motor.
Some yards buy them whole as aluminium motor, cbm 2, or al 3
PostPosted: Thu Dec 17, 2015 11:50 am
board sort buys them as CD/Disk/Floppy Drives IF the board is still on them... otherwise them buy them as shred material (which is probably less than a penny a pound right now).
You are better off taking the board off and sending that in and taking the rest of the drive to a local scrap yard.
PostPosted: Fri Dec 18, 2015 5:04 pm
The controller board on a 3.5" floppy drive will go as peripheral grade as long as the gold pins are intact on it. Remove the pins and the board goes down to low grade.
PostPosted: Sun Feb 14, 2016 8:52 am
I'm new to the board, and a little late on this discussion.... Just not quite clear if the board in floppy drive goes with cd drive boards or peripherals?
PostPosted: Sun Feb 14, 2016 2:21 pm
Boards from 3.5" drives are always peripheral if the gold pins are intact.
5.25" boards will be peripheral on the low end or cd/dvd controller on the high side. Depending on the board at hand.
8" drive boards are always going to be telco
PostPosted: Mon Feb 15, 2016 9:05 pm
thank you. that clears it up. will make a note on my peripheral board box to remember. happy scrapping!
