It is currently Sun Nov 01, 2026 8:19 pm
 Post subject: ip office phones
PostPosted: Fri Oct 16, 2020 8:21 am
I have about five hundred ip office phones that I want to scrap and I need to know what the scrape prices on the phones and if the handsets and the base need to go with them or if I just need to pull the cards out of them and what will they be telco boards or what thanks
 Post subject: Re: ip office phones
PostPosted: Fri Oct 16, 2020 12:12 pm
A picture would help immensely, to answer your questions.
PostPosted: Fri Oct 16, 2020 1:28 pm
Whole office phones are currently 12č per pound.
You could send the handsets or not. Not sending them reduces weight but there’s nothing special in most.
As for pulling them apart that’s a bit different.
On the lowest end of the scale you get a peripheral board.
A low grade board.
A small pile of wire
A bunch of plastic
A small screen
Some tin Mylar
2 magnetic packages. Speaker/receiver
And a block of steel
On the high end like TP/IA switch phones with token controllers you get a few pounds of high telco plus all the above. And lead or even copper weights in the handset.
PostPosted: Tue Nov 03, 2020 4:32 pm
If the phones are not too old some companies pay 2 to 3 dollars per phone to refurb and resell. You might want to look into that instead or pulling them apart.
