It is currently Sun Nov 01, 2026 9:40 am
PostPosted: Tue Nov 24, 2020 1:50 am
So let’s quickly break down what is inside those heads.
From the giant 4 track of the pre 60s to the miniature nanometer level heads for 1” spinning hard disks.
Outer shell: steel. Newer ones use an iron nickel chromium steel. Older ones use iron nickel and aluminium steel.
Iron ferrite band.
The actual head arm.
(post 76)Signal controller IC.
Inside:
Copper coil.
Steel coil
Compressed Head package
Compressed head package:
Contact- often ferrite
Soft Metallic ceramic —:
Ranges.
NFe
NGa
NMg
Etc.
Conductive film
Rhodium spacer
Metallic spacer- varies by age and manufacturer
î
Each with a rubber or plastic foam spacer between them, depending on age.
Bias braces
2x
CoPtCr is most common today.
Head
Package
V
Layout
[ ] <@- #-~ arm/wires
