It is currently Thu Oct 29, 2026 2:27 am
PostPosted: Thu Sep 30, 2021 7:58 pm
So, as careful as I am, every so often a soldered chip / flatpack pulls off the board when I'm removing a glued-on heat sink (or worse, a gold-cap chip!). What is the correct protocol to avoid having the board downgraded? Do I need to re-attach it somehow? Do I just include it loose with the the board? Or does the removed component have to be sold separately?
Thanks!
PostPosted: Thu Sep 30, 2021 8:05 pm
Based on reading other forum posts, it should be fine if you tape the chip back on with clear tape
PostPosted: Thu Sep 30, 2021 8:11 pm
They're on there with tape now, but I was thinking maybe a small drop of hot glue would be better.
