It is currently Fri Nov 06, 2026 4:47 am
 Post subject: weighting
PostPosted: Fri Aug 08, 2025 4:54 pm
I have Gaylord's of power supply's and don't have a way to weight when I bring them in will you guys weight them out for me. its hard to try and weight them as i put them in the box one at a time
thanks
 Post subject: Re: weighting
PostPosted: Fri Aug 08, 2025 6:06 pm
Contact Chris for directions on this if you are bringing them in.
PostPosted: Sat Aug 23, 2025 8:41 pm
Follow lost's advice.
In the future if you can get a weight on the pallet and box to at least provide a tare weight that will be useful. You might also consider putting things into a smaller container and when it's full weigh that before dumping into the gaylord. Then you have the entire gaylord to write on, put the added weights on the box and add them as you go.
