It is currently Thu Nov 05, 2026 5:41 pm
 Post subject: ERPOM and IC Help
PostPosted: Sun Sep 28, 2025 11:51 am
Looking for a little help to know how classify these.
ERPOM - clear window with the viewable gold?
IC Chips - I have what seems to be plastic and ceramic. Any difference of between the two when sending in?
 Post subject: Re: ERPOM and IC Help
PostPosted: Sun Sep 28, 2025 1:19 pm
Those are IC Chip category. That's how I send them in.
Upload to O.S.C.A.R. How are they evaluated?
I do believe Boardsort should expand the photographs and/or post a video to show a wider range of acceptable chips. Only to help out those new to scrapping.
As always you can email Boardsort directly for an evaluation.
PostPosted: Fri Nov 07, 2025 2:53 am
General rule of thumb for the IC category acceptance. Black or colored square/rectangle, labeled "IC" or "U" on the PCB.
Has at least 6-8+ legs on 2 or more sides
Will have a tiny little dot or dimple in the corner
Sometimes called "dies" IC's chips on COF's or FFC's are accepted as IC's
PostPosted: Fri Nov 07, 2025 2:56 am
Not all IC's go as IC. Some are higher value and go for a specific CPU class.
PostPosted: Fri Nov 07, 2025 9:51 am
viewtopic.php?f=7&t=3049&p=13640
That's a good reference to check, lost has said he needs to update it but it's still pretty accurate
