It is currently Thu Sep 10, 2026 10:06 pm
PostPosted: Tue Mar 31, 2026 12:12 am
Do flat packs go with no gold tap BGA category or do they go with IC category when scrapping?
PostPosted: Tue Mar 31, 2026 12:32 pm
If it's a bga flatpack but without a gold tab there is a separate category for those at the bottom of the chips section of the price list. There's an example image there as well.
PostPosted: Tue Mar 31, 2026 1:08 pm
I should’ve been more clear, what if it’s a non-BGA flat pack? What category do those go in?
PostPosted: Tue Mar 31, 2026 1:47 pm
Then it's likely an IC.
Pictures are always helpful to be more certain.
PostPosted: Tue Mar 31, 2026 10:10 pm
This style
PostPosted: Thu Apr 02, 2026 6:23 pm
This link may be helpful.
https://madpcb.com/glossary/chip-package/
Yes. It is a type of flatpack. But it goes into the Boardsort IC chip category.
Another link.
https://boardsort.com/escrapforum/viewtopic.php?f=4&t=21797&hilit=Flatpack
It's easy to lose the forest for the trees.
You can technically call all integrated circuits in every way shape or form. DIE CHIPS..
Why? It goes back to the original manufacturing process. You would have a large number of ICs made on a large silicon wafer. Each indvidual IC was called a DIE Then diced the wafer apart and recover the individual DIE. The engineers call all those loose DIE. DIE CHIPS. The term stuck. Then you place the DIE in the type of package you want to carry it as in contain the DIE. The CHIP. The DIE CHIP. So you have all kinds of different packages. BGA. PGA. FLATPACK. DIP. And on and on and on. There are advantages and disadvantages to each package type. Now we refer to an integrated circuit by it's package type. It can get confusing.
But your picture is a type of flatpack. It goes into the Boardsort escrap category of IC Chips. It is not a BGA.
The terminology can get us lost. Its the gold bonding wire and any gold trace in them that gives value. View a few U-tube videos on IC manufacturing. You may find it interesting.
PostPosted: Sun Apr 05, 2026 1:55 pm
That's a flat pack.
Flat pack refers to the type and construction of the chip. Low character to the PCB.
Most SMD type chips are considered "flat packs"
