It is currently Sun Oct 25, 2026 5:58 pm
PostPosted: Tue Apr 14, 2026 2:39 pm
I would think #1 unless there's heavy corrosion or solder on your particular one
PostPosted: Tue Apr 14, 2026 4:27 pm
If You really wanted to you could probably find some sort of spec sheet on what kind of copper is used to make them, you could verify that the percentage of copper is high enough for number one.
A scrapyard that’s unfamiliar with that type of heat sink might see the fins and think that it’s not one solid block. ¯\_(ツ)_/¯
PostPosted: Tue Apr 14, 2026 8:34 pm
Name brand ones are clean #1 or copper heatsink.
Lower cost generics tend to be #2 they have up to 5% or so mixed metals like zinc and tin.
PostPosted: Wed Apr 15, 2026 1:26 pm
You’re fine with #2 for the batch. At worst.
