It is currently Thu Sep 10, 2026 8:17 pm
PostPosted: Tue Apr 14, 2026 5:12 pm
Like these?
Gonna depend on the board, low or high peripheral likely for most.
(I realize two of those are for 3.5" drives)
PostPosted: Tue Apr 14, 2026 8:30 pm
An adaptor that is xtype-SATA is usually high peripheral if it has its own controller chips.
If not its connector end
The hard drive board is low grad hard drive
PostPosted: Tue Apr 14, 2026 9:35 pm
There's no boards directly off a hard drive in that image, their all from external enclosures I took apart and use occasionally still.
But if one of those boards has everything to qualify as a hdd board then I guess that helps answer Austin's question.
PostPosted: Wed Apr 15, 2026 9:53 am
Oh!
Never seen that before. Probably low grade (or worse if the lack of substantial gold pins makes a difference)
PostPosted: Wed Apr 15, 2026 2:04 pm
austin86 wrote:
no not the adapters that plug into the hdd. some external hard drives have a board on the hdd with usb/firewire and not sata/ide
like this
Low grade hard drive board
PostPosted: Wed Apr 15, 2026 2:05 pm
Sorry I was responding to Austin directly not to your post. ;)
PostPosted: Wed Apr 15, 2026 2:22 pm
No worries, I wasn't sure so figured I'd clarify if there was any confusion with the picture
