It is currently Sat Oct 31, 2026 1:14 am
 Post subject: Processors
PostPosted: Fri Apr 08, 2016 1:07 am
Does the copper sink under the aluminum heatsink need to be removed from the processors?
TAC
TAC
 Post subject: Re: Processors
PostPosted: Fri Apr 08, 2016 2:01 pm
If you are referring to the short flat stubby heat spreader that is attached to some processors no you do not have to remove that. Paragraph
ceramic processors that have an integrated spreader will go as a AMD ceramic
Green fibre processes that have a flat heat spreader will go as green fibre with metal rate
