It is currently Sun Oct 25, 2026 10:52 am
 Post subject: Broken BGA Gold Tab
PostPosted: Mon Jun 15, 2026 3:40 pm
Accidentally broke a gold tab BGA. Curious if it is still the same price or did I make it worthless?
 Post subject: Re: Broken BGA Gold Tab
PostPosted: Mon Jun 15, 2026 4:04 pm
Came off of an AMD MB
PostPosted: Tue Jun 16, 2026 10:28 am
A piece of tape is fine.
PostPosted: Tue Jun 16, 2026 12:43 pm
austin86 wrote:
nah that will buff out.
IDK about that, part of me wants to say you can slap a piece of tape on it and send it but IDK, I would email Chris about it or wait for others to chime in.
I appreciate both of you for taking the time to read all of my questions and replies. They have truly helped me out over the last couple of weeks.
I did go ahead and slapped some tape on it to piece it back together and threw it in with my other BGA's. Reason I went ahead and removed it was based on the feedback from @austin86. I know you mentioned that was your personal opinion but I agreed with you and went with it. I was just in too much of a hurry and did not take my time removing it from the AMD that was discussed in another post.
austin86 wrote:
remove heat sinks and cpu and it's a and motherboard. id be temped to remove the gold tab flat pack, don't normally see them on am/fm boards, probably could get away with it and keep the same grade but that's just me
PostPosted: Tue Jun 16, 2026 2:11 pm
austin86 wrote:
Should be good to sneak it in as a am/fm board, still don't be shocked if it does get a down grade. Why I would remove it is because most AM2+ am3m am3+ am4 boards do not have gold tabbed chips, really only 754 and some AM2/939, and have gold tabs. Since a large bulk of the AM/FM boards don't have them I would think its safe to remove it with the board you posted a photo of. However removing gold tabs from a motherboard most of the time will downgrade it. AM/FM boards are the only ones I would think of removing them on.
EDIT: It looks like I-Series boards are in the same category as AM/FM boards and I never once seen a gold tab on one of those outside a few rare server boards with a onboard GPU or raid chip, is its likely safe to remove the gold tab on all of them. But that's just IMO.
It is all good, I appreciate the input. I am here to learn and with that, we all have to live to learn so if it is wrong, it was my decision. As Motley Crue once said, "Take a Ride on the Wild Side" lol.
PostPosted: Fri Jun 19, 2026 1:14 pm
Grab your packing tape and tape the chip back to the board
Problem solved
